[geos-devel] [GEOS] #985: Replace sort to min_element in SubgraphDepthLocater::getDepth
geos-trac at osgeo.org
Mon Sep 9 08:43:26 PDT 2019
Reporter: dkvash | Owner: geos-devel@…
Type: patch | Status: new
Priority: major | Milestone:
Component: Default | Version: master
Severity: Unassigned | Keywords: SubgraphDepthLocater
SubgraphDepthLocater::getDepth uses heavy std::sort to find minimum
DepthSegment, this patch replaces sort to a more appropriate
std::min_element.
Origin implementation also relies on a Collections.min instead of heavy
sort.
https://github.com/locationtech/jts/blob/jts-1.16.1/modules/core/src/main/java/org/locationtech/jts/operation/buffer/SubgraphDepthLocater.java#L53
Ticket URL: <https://trac.osgeo.org/geos/ticket/985>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
