[geos-devel] [GEOS] #949: static link of geos_unit test app fails under CMake
geos-trac at osgeo.org
Fri Sep 13 17:03:10 PDT 2019
Reporter: darkblueb | Owner: geos-devel@…
Type: defect | Status: new
Priority: minor | Milestone: 3.8.0
Component: Build/Install (cmake) | Version: master
Severity: Unassigned | Resolution:
Keywords: test |
Comment (by dbaston):
Works for me in current configuration using `cmake
-DBUILD_SHARED_LIBS=NO`.
Is it still a issue for you?
Ticket URL: <https://trac.osgeo.org/geos/ticket/949#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
