[geos-devel] [GEOS] #988: Doxygen error check with cmake build
geos-trac at osgeo.org
Sat Sep 14 12:15:55 PDT 2019
Reporter: nila | Owner: geos-devel@…
Type: enhancement | Status: new
Priority: major | Milestone:
Component: Build/Install (cmake) | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by dbaston):
Thank you! I had started along these lines but hadn't finished.
To ignore "not documented" errors I think we should set the appropriate
flag in Doxyfile rather than grepping the output.
It would be nice to understand the source of the "invalid tag" errors too
; maybe we can avoid those by specifying a required Doxygen verison.
These changes would allow a simpler solution of just having Doxygen stop
on error instead of parsing the log files.
Opening a pull request at GitHub will test the changes against roughly 40
platforms; however, documentation is only built on Linux. I will look at
enabling Doxygen for OS X / Windows builds.
Ticket URL: <https://trac.osgeo.org/geos/ticket/988#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
