[geos-devel] [GEOS] #714: [Patch] Don't create default GeometryFactory on the heap
GEOS geos-trac at osgeo.org
Wed Sep 18 09:42:41 PDT 2019
 Reporter:  smani       |       Owner:  geos-devel@…
     Type:  patch       |      Status:  closed
 Priority:  minor       |   Milestone:  3.8.0
Component:  Default     |     Version:  3.4.2
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Comment (by Paul Ramsey <pramsey@…>):
 In [changeset:"db00eaf430de977449a238c9729e71e616f239e6/git" db00eaf/git]:
 #!CommitTicketReference repository="git"
 revision="db00eaf430de977449a238c9729e71e616f239e6"
 Allocate default geometryfactory on the stack
 Makes valgrind happier.
 References #714
 Thanks Sandro Mani
Ticket URL: <https://trac.osgeo.org/geos/ticket/714#comment:9>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
