[geos-devel] [GEOS] #949: static link of geos_unit test app fails under CMake
GEOS geos-trac at osgeo.org
Sun Sep 22 17:15:09 PDT 2019
 Reporter:  darkblueb              |       Owner:  geos-devel@…
     Type:  defect                 |      Status:  closed
 Priority:  minor                  |   Milestone:  3.8.0
Component:  Build/Install (cmake)  |     Version:  master
 Severity:  Unassigned             |  Resolution:  fixed
 Keywords:  test                   |
Comment (by darkblueb):
 master build, CMake 3.15, GEOS_BUILD_SHARED=OFF
  bin/
   perf_memleak_mp_prep   test_big_sweep_line_speed
 perf_geospreparedcontains
   perf_intersection   perf_interiorpoint_area   perf_rectangle_intersects
   perf_voronoi  example   astyle
   test_geos_unit   test_simplewkttester   test_xmltester
Ticket URL: <https://trac.osgeo.org/geos/ticket/949#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
