[geos-devel] [GEOS] #896: CAPI functions do not preserve SRID
GEOS geos-trac at osgeo.org
Thu Sep 26 09:57:28 PDT 2019
 Reporter:  dbaston     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.8.0
Component:  Default     |     Version:  3.6.2
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by dbaston):
 I'm less and less understanding the use case for GEOS to carry a 4-byte
 SRID on every geometry (actually 8 bytes I think because of padding), with
 which it does nothing, especially given that we already provide a
 "userData" pointer which is probably also not used frequently. Given that
 the behavior has been incorrect for years and nobody besides me has
 complained, I'd be inclined to remove SRID in the next major release.
Ticket URL: <https://trac.osgeo.org/geos/ticket/896#comment:14>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
