[geos-devel] [GEOS] #1005: Writing POINT EMPTY in WKB
geos-trac at osgeo.org
Wed Aug 5 05:48:24 PDT 2020
Reporter: Mike Taves | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: master
Severity: Annoyance | Resolution:
Keywords: |
Comment (by jorisvandenbossche):
What are the thoughts about adding this special case to GEOS?
I think it would be good to have consistency in reading vs writing in
GOES, and enable a full roundtrip.
Further, PostGIS does this as well, and I think Shapely/PyGEOS would like
to do this as well (in which case they need to add a special case on top
of their usage of GEOS if it is not changed in GEOS itself).
Ticket URL: <https://trac.osgeo.org/geos/ticket/1005#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
