[geos-devel] [GEOS] #718: Port InteriorIntersectionFinder improvements from JTS
geos-trac at osgeo.org
Tue Aug 11 13:57:34 PDT 2020
Reporter: strk | Owner: geos-devel@…
Type: enhancement | Status: closed
Priority: major | Milestone: 3.9.0
Component: Default | Version: master
Severity: Unassigned | Resolution: invalid
Keywords: |
Changes (by pramsey):
* status: new => closed
* resolution: => invalid
Comment:
The InteriorIntersectionFinderAdder only seems to be used in the
MCIndexSnapRounder which in turn is used almost nowhere. This code line
seems to have died out. The new snap rounder for overlayng will likely
form the basis for any future snap rounding code in JTS and GEOS.
Ticket URL: <https://trac.osgeo.org/geos/ticket/718#comment:6>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
