[geos-devel] Renaming TestFunction* to TestOverlay as per JTS change ?
Sandro Santilli
strk at kbt.io
Mon Aug 17 10:58:38 PDT 2020
On Mon, Aug 17, 2020 at 07:04:10PM +0200, Sandro Santilli wrote:
> On Mon, Aug 17, 2020 at 06:45:50PM +0200, Sandro Santilli wrote:
> > Commit 81b2a236abca2d992572ae1d49dd9b44347e1b80 in JTS
> > renamed all TestFunction*.xml files to TestOverlay*.xml
> > In order to better track upstream, I think it'd be useful for GEOS to
> > do the same. Martin: was it really only a rename or did anything else
> > change ?
> I noticed some tests are actually missing from GEOS, like
> TestOverlayEmpty. Any reason why we shouldn't port them over ?
I found out: Empty test was failing.
I've nonetheless done the renaming and the fix for Empty
with commit 264168eeb0f921f0edfc9acab6f12ee5357a15ae
Testsuite passes, for both GEOS and PostGIS.
Hopefully this will help with OverlayNG test comparison.
--strk;
