[geos-devel] [GEOS] #1044: [OverlayNG] general/TestOverlayAA.xml fails
GEOS geos-trac at osgeo.org
Tue Aug 18 13:10:24 PDT 2020
 Reporter:  strk        |      Owner:  geos-devel@…
     Type:  defect      |     Status:  new
 Priority:  major       |  Milestone:  3.9.0
Component:  Default     |    Version:  master
 Severity:  Unassigned  |   Keywords:
  Description: AA - A hole close to shell, B coincident with A
  Geometry A: POLYGON ((10 100, 10 10, 100 10, 100 100, 10 100), (90 90, 11
 90, 10 10, 90 11, 90 90))
  Geometry B: POLYGON ((10 30, 10 10, 30 10, 30 30, 10 30))
  Expected result: MULTILINESTRING ((10 10, 30 10), (10 10, 10 30))
  Obtained result: MULTIPOINT (30 10, 10 30)
Ticket URL: <https://trac.osgeo.org/geos/ticket/1044>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
