[geos-devel] [GEOS] #1044: [OverlayNG] general/TestOverlayAAPrec.xml fails
geos-trac at osgeo.org
Tue Aug 18 13:37:42 PDT 2020
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.9.0
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by strk):
I was wrong about JTS, it fails with the same error. The difference is
that while JTS uses the OLD Overlay code for XML test "intersection", GEOS
uses the OverlayNG when compiled with --enable-overlayng.
Martin: I find the expected output more correct than the obtained one,
don't you ?
Case x.xml - #1 (4): AA - A hole close to shell, B coincident with A
Test Failed (A intersectionng B)
Expected: MULTILINESTRING ((10 30, 10 10),
(10 10, 30 10))
Actual: MULTIPOINT ((30 10), (10 30))
Ticket URL: <https://trac.osgeo.org/geos/ticket/1044#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
