[geos-devel] [GEOS] #1047: GEOS Panics on GeometryCollection with 1 MultiPolygon object
geos-trac at osgeo.org
Sat Aug 22 09:02:34 PDT 2020
Reporter: otan | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: 3.8.0
Severity: Unassigned | Keywords:
Tested on v3.8.1.
The following code will seg fault:
#include <geos_c.h>
#include <string>
using namespace std;
void geos_message_handler(const char *fmt, ...) {}
void geos_error_handler(const char *fmt, ...) {}
int main() {
string aEWKB =
"01020000000200000000000000000000000000000000000000000000000000F03F0000000000000000";
string bEWKB =
"0107000000010000000106000000010000000103000000010000000500000008690b3a70a9c347540a11d15993eec7e04b9e4d8fd2cb4702907c2929abe847d02aef5652e3cec72c1b57867da3dd47bbf47698d501eac7ccc0d287b380d44708690b3a70a9c347540a11d15993eec7";
initGEOS(&geos_message_handler, &geos_error_handler);
auto wkbReader = GEOSWKBReader_create();
auto geomA = GEOSWKBReader_read(wkbReader, reinterpret_cast<const
unsigned char*>(aEWKB.data()), aEWKB.length());
auto geomB = GEOSWKBReader_read(wkbReader, reinterpret_cast<const
unsigned char*>(bEWKB.data()), bEWKB.length());
GEOSIntersects(geomA, geomB);
return 0;
Seems like geometryN does not work and returns NULL:
_ZN4geos9algorithm6locate24SimplePointInAreaLocator20locatePointInPolygonERKNS_4geom10CoordinateEPKNS3_7PolygonE
/Users/otan/go/src/github.com/cockroachdb/cockroach/lib/libgeos.dylib:0
pc=0x14218db3
_ZN4geos9geomgraph11EdgeEndStar11getLocationEiRKNS_4geom10CoordinateEPNSt3__16vectorIPNS0_13GeometryGraphENS6_9allocatorIS9_EEEE
pc=0x1423fce8
_ZN4geos9geomgraph11EdgeEndStar16computeLabellingEPNSt3__16vectorIPNS0_13GeometryGraphENS2_9allocatorIS5_EEEE
pc=0x1423f936
_ZN4geos9operation6relate14RelateComputer9computeIMEv
pc=0x142a95a3
_ZN4geos9operation6relate8RelateOp6relateEPKNS_4geom8GeometryES6_
pc=0x142ab1f2
_ZNK4geos4geom8Geometry10intersectsEPKS1_
pc=0x14220773
GEOSIntersects_r
Ticket URL: <https://trac.osgeo.org/geos/ticket/1047>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
