[geos-devel] [GEOS] #1081: TopologyPreservingSimplifier / GEOSTopologyPreserveSimplify on Windows
GEOS geos-trac at osgeo.org
Tue Dec 1 15:19:52 PST 2020
 Reporter:  Mike Taves  |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  3.9.0
Component:  Unit Tests  |     Version:  master
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by robe):
 FWIW My Mingw-w64 build Windows seems fine. So not all windows, assume
 just VC++ compiled and possibly specific versions.
 POSTGIS="3.1.0alpha3 3.1.0alpha2-164-gd2d5c9f98" [EXTENSION] PGSQL="130"
 GEOS="3.9.0-CAPI-1.14.0" PROJ="7.1.1" LIBXML="2.9.9" LIBJSON="0.12"
 LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)"
 Using GEOS as of yesterday branch (also tested with one from a month ago).
  SELECT ST_AsText(ST_SimplifyPreserveTopology(
      'MULTILINESTRING((0 0, 50 0, 70 0, 80 0, 100 0), (0 0, 50 1, 60 1,
 100  0))', 10.0));
 yields consistently
 MULTILINESTRING((0 0,100 0),(0 0,50 1,100 0))
Ticket URL: <https://trac.osgeo.org/geos/ticket/1081#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
