[geos-devel] 3.9.0beta + GEOSwift + Linux
Paul Ramsey
pramsey at cleverelephant.ca
Wed Dec 2 15:17:59 PST 2020
Done! :)
> On Dec 2, 2020, at 12:47 PM, Andrew Hershberger <andrew.d.hershberger at gmail.com> wrote:
> The thread I started on the Swift forums has reached a conclusion (https://forums.swift.org/t/confused-about-cxxlanguagestandard/42402). I'd been conflating the C++ language standard (which is what I was specifying via the Swift Package definition) and the C++ Standard Library (which isn't exposed in a useful way to the Swift Package definition API at the moment). Even if it were possible to require a specific C++ Standard Library, it seems like it'd be more flexible to add the #import <algorithm> to the 2 files (LineLimiter.cpp and KdTree.cpp).
> Andrew
> On Tue, Dec 1, 2020 at 12:48 PM Andrew Hershberger <andrew.d.hershberger at gmail.com> wrote:
> In case anyone is interested, here's the thread I started on the Swift forums: https://forums.swift.org/t/confused-about-cxxlanguagestandard/42402
> On Tue, Dec 1, 2020 at 12:13 AM Andrew Hershberger <andrew.d.hershberger at gmail.com> wrote:
> Seems like the macOS builds are getting their <vector> from llvm's libc++ but that the build in the Swift Docker container is using the GNU C++. LLVM's vector (Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/vector) imports algorithm. The GNU C++ version doesn't (at least not directly). I find this Swift Package Manager behavior on Linux strange because the GEOSwift/geos package definition specifically requests "cxx11" (as opposed to "gnucxx11"). I'll see whether someone from the Swift team can shed some light on what's going on here.
> On Mon, Nov 30, 2020 at 11:40 PM Andrew Hershberger <andrew.d.hershberger at gmail.com> wrote:
> That works. I had to add it to KdTree.cpp as well. Agree that it's strange.
> On Mon, Nov 30, 2020 at 9:17 PM Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> > On Nov 30, 2020, at 7:15 PM, Andrew Hershberger <andrew.d.hershberger at gmail.com> wrote:
> > Found another issue with the beta when testing GEOSwift on Linux (specifically, compiling in a Docker container using the Swift Docker image). Here's what I'm doing:
> > $ sudo docker run -it --rm swift /bin/bash
> > # cd home
> > # git clone https://github.com/GEOSwift/GEOSwift.git
> > # cd GEOSwift
> > # git checkout geos-3.9.0-testing
> > # swift test --enable-test-discovery -v
> > Among other things, this yields the following line for LineLimiter.cpp:
> > /usr/bin/clang -target x86_64-unknown-linux-gnu -fPIC -g -O0 -DSWIFT_PACKAGE=1 -DDEBUG=1 -fblocks -fmodules -fmodule-name=geos -I /home/GEOSwift/.build/checkouts/geos/Sources/geos/public -fmodules-cache-path=/home/GEOSwift/.build/x86_64-unknown-linux-gnu/debug/ModuleCache -DUSE_UNSTABLE_GEOS_CPP_API -I/home/GEOSwift/.build/checkouts/geos/Sources/geos/include -MD -MT dependencies -MF /home/GEOSwift/.build/x86_64-unknown-linux-gnu/debug/geos.build/src/operation/overlayng/LineLimiter.cpp.d -std=c++11 -c /home/GEOSwift/.build/checkouts/geos/Sources/geos/src/operation/overlayng/LineLimiter.cpp -o /home/GEOSwift/.build/x86_64-unknown-linux-gnu/debug/geos.build/src/operation/overlayng/LineLimiter.cpp.o
> > And this corresponding error:
> > /home/GEOSwift/.build/checkouts/geos/Sources/geos/src/operation/overlayng/LineLimiter.cpp:121:24: error: no member named 'unique' in namespace 'std'
> > ptList->erase(std::unique(ptList->begin(), ptList->end()), ptList->end());
> Add #include <algorithm>
> to LineLimiter.cpp see if that helps?
> Not sure why only your version would have this problem. Maybe it's in different headers sometimes?
> > Here's some clang version info:
> > clang version 10.0.0 (git at github.com:apple/llvm-project.git 3093af41dd65ad466dcd5603e9289244edfee4f5)
> > Target: x86_64-unknown-linux-gnu
> > Thread model: posix
> > InstalledDir: /usr/bin
> > Any idea what might be going on here?
> > geos-devel mailing list
> > geos-devel at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/geos-devel
