[geos-devel] 3.9.0beta2
Paul Ramsey
pramsey at cleverelephant.ca
Fri Dec 4 16:16:21 PST 2020
> On Dec 4, 2020, at 4:08 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>> On Dec 4, 2020, at 1:10 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>>> On Dec 3, 2020, at 10:18 PM, Sebastiaan Couwenberg <sebastic at xs4all.nl> wrote:
>>> On 12/3/20 12:17 AM, Paul Ramsey wrote:
>>>> without any further ado, here's a beta2 release for your testing pleasure
>>> testrunner fails on arm64, ppc64el, powerpc, ppc64, riscv64:
>> Have we ever passed? Perhaps I made a big mistake removing ttmath.
>> Anyways, here's what I've learned today, testing on an AWS ARM64 server.
>> * Still no obvious reason why these platforms shouldn't just work, if they implement IEEE conforming operations on double.
>> * There's something called FLT_EVAL_METHOD in <cfloat> which might indicate non-IEEE handling of double, but... my test server insists it is FLT_EVAL_METHOD == 0 "evaluate just to the range and precision of the type".
>> Wondering if there was a brutal hack-around, and noting that "long double" is increasingly a "thing", I took our DD class, and hacked out all the smarts and substituted long double implementations.
>> https://github.com/pramsey/geos/tree/dd-arm
>> Interestingly, this implementation passes all the geos::math::DD tests! The ARM64 long double appears to have a full 128bit implementation. Running the same thing on Intel x64 fails a number of tests. This is probably because the long double implementation on x64 has only 80 bits (according to the internet).
>> Does all this test passing mean that a direct use of long double will work on platforms that support it? Apparently not. The ARM build still fails on quite a few tests of varying sorts, just not on the DD tests.
>> 90 - unit-capi-GEOSVoronoiDiagram (Failed)
>> 140 -unit-linearref-LengthIndexedLine (Failed)
>> 208 - general-TestCentroid (Failed)
>> 260 - issue-issue-geos-275 (Failed)
>> 267 - issue-issue-geos-398 (Failed)
>> 349 - robust-TestOverlay-pg-list (Failed)
>> Where does this leave us? With a long research project on ARM64 to track down why these tests fail and/or why the DD implementation fails.
> Since this was a finite set of test failures and I was wondering if these failures were "real" or "tiny", I started going through them and the Voronoi failures seemed to fall into the "tiny" category. There was/is clearly a double precision equality test in the code that is returning true on one platform and false on another, because the answers are very very similar.
> When I moved onto unit-linearref-LengthIndexedLine test, there wasn't any good printed debugging, so I broke out the debugger, and I had to rebuild in Debug mode. Guess what:
> 100% tests passed, 0 tests failed out of 364
> Yep, with the hardware long double for precision and in debug mode every test passes. So the problems on ARM64 are even *more* awful to figure out. Something about the optimized release build is different enough to matter.
In fact, a debug build passes all tests straight off master, no replacement work on DD required. This perhaps explains my success testing GEOS on ARM earlier.
P
