[geos-devel] [GEOS] #910: Difference operation resulted with a wrong geometry as a result of a precision limitation
geos-trac at osgeo.org
Wed Dec 9 13:33:34 PST 2020
Reporter: yanivnavon | Owner: geos-
| devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.10.0
Component: Default | Version: 3.6.2
Severity: Significant | Resolution: invalid
Keywords: polygon, geometry, geometries, |
difference, union, multipolygon |
Changes (by pramsey):
* status: new => closed
* resolution: => invalid
Comment:
As of 3.9 you might find the snap-rounded operations (difference with a
tolerance) provide more predictability in terms of holding to a
particularly domain grid, assuming you can stand the initial round-off
stop.
Ticket URL: <https://trac.osgeo.org/geos/ticket/910#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
