[geos-devel] GEOS 3.9.0 Released
Greg Troxel
gdt at lexort.com
Mon Dec 14 11:36:42 PST 2020
(I am late in trying this, for no good reason.)
I am doing a trial update of pkgsrc/geography/geos to 3.9.0 from 3.8.1.
I am seeing a lot of header file withdrawals, and it is not clear to me
that they are explained by "new overlay engine" (but also not clear that
they are not explained by this). Hence I am posting my diff of
installed files and would appreciate someone taking a quick scan and
pronouncing "those changes are expected" vs "we have a problem".
Given the new engine, I am guessing I should not update pkgsrc today
since we are going into freeze within days for 12/31 quarterly stable
release. Instead, I'd hold off until just after freeze. Please also
let me know if you think that's confused.
Thanks,
Greg
diff -u -p -r1.16 PLIST
--- PLIST 11 Mar 2020 12:52:06 -0000 1.16
+++ PLIST 14 Dec 2020 19:35:01 -0000
@@ -26,6 +26,8 @@ include/geos/algorithm/PointLocator.h
include/geos/algorithm/RayCrossingCounter.h
include/geos/algorithm/RayCrossingCounterDD.h
include/geos/algorithm/RobustDeterminant.h
+include/geos/algorithm/construct/LargestEmptyCircle.h
+include/geos/algorithm/construct/MaximumInscribedCircle.h
include/geos/algorithm/distance/DiscreteFrechetDistance.h
include/geos/algorithm/distance/DiscreteHausdorffDistance.h
include/geos/algorithm/distance/DistanceToPoint.h
@@ -33,24 +35,13 @@ include/geos/algorithm/distance/PointPai
include/geos/algorithm/locate/IndexedPointInAreaLocator.h
include/geos/algorithm/locate/PointOnGeometryLocator.h
include/geos/algorithm/locate/SimplePointInAreaLocator.h
-include/geos/algorithm/ttmath/ttmath.h
-include/geos/algorithm/ttmath/ttmathbig.h
-include/geos/algorithm/ttmath/ttmathdec.h
-include/geos/algorithm/ttmath/ttmathint.h
-include/geos/algorithm/ttmath/ttmathmisc.h
-include/geos/algorithm/ttmath/ttmathobjects.h
-include/geos/algorithm/ttmath/ttmathparser.h
-include/geos/algorithm/ttmath/ttmaththreads.h
-include/geos/algorithm/ttmath/ttmathtypes.h
-include/geos/algorithm/ttmath/ttmathuint.h
-include/geos/algorithm/ttmath/ttmathuint_noasm.h
-include/geos/algorithm/ttmath/ttmathuint_x86.h
-include/geos/algorithm/ttmath/ttmathuint_x86_64.h
-include/geos/algorithm/ttmath/ttmathuint_x86_64_msvc.asm
include/geos/constants.h
+include/geos/edgegraph/EdgeGraph.h
+include/geos/edgegraph/EdgeGraphBuilder.h
+include/geos/edgegraph/HalfEdge.h
+include/geos/edgegraph/MarkHalfEdge.h
include/geos/export.h
include/geos/geom.h
-include/geos/geom/BinaryOp.h
include/geos/geom/Coordinate.h
include/geos/geom/Coordinate.inl
include/geos/geom/CoordinateArraySequence.h
@@ -73,6 +64,7 @@ include/geos/geom/GeometryComponentFilte
include/geos/geom/GeometryFactory.h
include/geos/geom/GeometryFactory.inl
include/geos/geom/GeometryFilter.h
+include/geos/geom/HeuristicOverlay.h
include/geos/geom/IntersectionMatrix.h
include/geos/geom/LineSegment.h
include/geos/geom/LineSegment.inl
@@ -86,20 +78,26 @@ include/geos/geom/MultiPolygon.h
include/geos/geom/MultiPolygon.inl
include/geos/geom/Point.h
include/geos/geom/Polygon.h
+include/geos/geom/Position.h
include/geos/geom/PrecisionModel.h
include/geos/geom/PrecisionModel.inl
+include/geos/geom/Quadrant.h
+include/geos/geom/Quadrant.inl
include/geos/geom/Triangle.h
include/geos/geom/prep/AbstractPreparedPolygonContains.h
include/geos/geom/prep/BasicPreparedGeometry.h
include/geos/geom/prep/PreparedGeometry.h
include/geos/geom/prep/PreparedGeometryFactory.h
include/geos/geom/prep/PreparedLineString.h
+include/geos/geom/prep/PreparedLineStringDistance.h
include/geos/geom/prep/PreparedLineStringIntersects.h
+include/geos/geom/prep/PreparedLineStringNearestPoints.h
include/geos/geom/prep/PreparedPoint.h
include/geos/geom/prep/PreparedPolygon.h
include/geos/geom/prep/PreparedPolygonContains.h
include/geos/geom/prep/PreparedPolygonContainsProperly.h
include/geos/geom/prep/PreparedPolygonCovers.h
+include/geos/geom/prep/PreparedPolygonDistance.h
include/geos/geom/prep/PreparedPolygonIntersects.h
include/geos/geom/prep/PreparedPolygonPredicate.h
include/geos/geom/util/ComponentCoordinateExtracter.h
@@ -115,8 +113,6 @@ include/geos/geom/util/PointExtracter.h
include/geos/geom/util/PolygonExtracter.h
include/geos/geom/util/ShortCircuitedGeometryVisitor.h
include/geos/geom/util/SineStarFactory.h
-include/geos/geomUtil.h
-include/geos/geomgraph.h
include/geos/geomgraph/Depth.h
include/geos/geomgraph/Depth.inl
include/geos/geomgraph/DirectedEdge.h
@@ -139,9 +135,6 @@ include/geos/geomgraph/Node.h
include/geos/geomgraph/NodeFactory.h
include/geos/geomgraph/NodeMap.h
include/geos/geomgraph/PlanarGraph.h
-include/geos/geomgraph/Position.h
-include/geos/geomgraph/Quadrant.h
-include/geos/geomgraph/Quadrant.inl
include/geos/geomgraph/TopologyLocation.h
include/geos/geomgraph/TopologyLocation.inl
include/geos/geomgraph/index/EdgeSetIntersector.h
@@ -156,8 +149,6 @@ include/geos/geomgraph/index/SimpleSweep
include/geos/geomgraph/index/SweepLineEvent.h
include/geos/geomgraph/index/SweepLineEventObj.h
include/geos/geomgraph/index/SweepLineSegment.h
-include/geos/geomgraphindex.h
-include/geos/geosAlgorithm.h
include/geos/index/ItemVisitor.h
include/geos/index/SpatialIndex.h
include/geos/index/bintree/Bintree.h
@@ -174,7 +165,9 @@ include/geos/index/intervalrtree/Interva
include/geos/index/intervalrtree/IntervalRTreeLeafNode.h
include/geos/index/intervalrtree/IntervalRTreeNode.h
include/geos/index/intervalrtree/SortedPackedIntervalRTree.h
-include/geos/index/quadtree/DoubleBits.h
+include/geos/index/kdtree/KdNode.h
+include/geos/index/kdtree/KdNodeVisitor.h
+include/geos/index/kdtree/KdTree.h
include/geos/index/quadtree/IntervalSize.h
include/geos/index/quadtree/Key.h
include/geos/index/quadtree/Node.h
@@ -192,17 +185,14 @@ include/geos/index/strtree/ItemBoundable
include/geos/index/strtree/ItemDistance.h
include/geos/index/strtree/SIRtree.h
include/geos/index/strtree/STRtree.h
+include/geos/index/strtree/SimpleSTRdistance.h
+include/geos/index/strtree/SimpleSTRnode.h
+include/geos/index/strtree/SimpleSTRtree.h
include/geos/index/sweepline/SweepLineEvent.h
include/geos/index/sweepline/SweepLineIndex.h
include/geos/index/sweepline/SweepLineInterval.h
include/geos/index/sweepline/SweepLineOverlapAction.h
-include/geos/indexBintree.h
-include/geos/indexChain.h
-include/geos/indexQuadtree.h
-include/geos/indexStrtree.h
-include/geos/indexSweepline.h
include/geos/inline.h
-include/geos/io.h
include/geos/io/ByteOrderDataInStream.h
include/geos/io/ByteOrderDataInStream.inl
include/geos/io/ByteOrderValues.h
@@ -226,7 +216,8 @@ include/geos/linearref/LinearLocation.h
include/geos/linearref/LocationIndexOfLine.h
include/geos/linearref/LocationIndexOfPoint.h
include/geos/linearref/LocationIndexedLine.h
-include/geos/noding.h
+include/geos/math/DD.h
+include/geos/namespaces.h
include/geos/noding/BasicSegmentString.h
include/geos/noding/BasicSegmentString.inl
include/geos/noding/FastNodingValidator.h
@@ -256,21 +247,17 @@ include/geos/noding/SegmentString.h
include/geos/noding/SegmentStringUtil.h
include/geos/noding/SimpleNoder.h
include/geos/noding/SinglePassNoder.h
+include/geos/noding/ValidatingNoder.h
+include/geos/noding/snap/SnappingIntersectionAdder.h
+include/geos/noding/snap/SnappingNoder.h
+include/geos/noding/snap/SnappingPointIndex.h
include/geos/noding/snapround/HotPixel.h
include/geos/noding/snapround/HotPixel.inl
+include/geos/noding/snapround/HotPixelIndex.h
include/geos/noding/snapround/MCIndexPointSnapper.h
include/geos/noding/snapround/MCIndexSnapRounder.h
-include/geos/noding/snapround/SimpleSnapRounder.h
-include/geos/nodingSnapround.h
-include/geos/opBuffer.h
-include/geos/opDistance.h
-include/geos/opLinemerge.h
-include/geos/opOverlay.h
-include/geos/opPolygonize.h
-include/geos/opPredicate.h
-include/geos/opRelate.h
-include/geos/opValid.h
-include/geos/operation.h
+include/geos/noding/snapround/SnapRoundingIntersectionAdder.h
+include/geos/noding/snapround/SnapRoundingNoder.h
include/geos/operation/GeometryGraphOperation.h
include/geos/operation/IsSimpleOp.h
include/geos/operation/buffer/BufferBuilder.h
@@ -318,6 +305,34 @@ include/geos/operation/overlay/snap/Geom
include/geos/operation/overlay/snap/LineStringSnapper.h
include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h
include/geos/operation/overlay/snap/SnapOverlayOp.h
+include/geos/operation/overlayng/Edge.h
+include/geos/operation/overlayng/EdgeKey.h
+include/geos/operation/overlayng/EdgeMerger.h
+include/geos/operation/overlayng/EdgeNodingBuilder.h
+include/geos/operation/overlayng/EdgeSourceInfo.h
+include/geos/operation/overlayng/ElevationModel.h
+include/geos/operation/overlayng/IndexedPointOnLineLocator.h
+include/geos/operation/overlayng/InputGeometry.h
+include/geos/operation/overlayng/IntersectionPointBuilder.h
+include/geos/operation/overlayng/LineBuilder.h
+include/geos/operation/overlayng/LineLimiter.h
+include/geos/operation/overlayng/MaximalEdgeRing.h
+include/geos/operation/overlayng/OverlayEdge.h
+include/geos/operation/overlayng/OverlayEdgeRing.h
+include/geos/operation/overlayng/OverlayGraph.h
+include/geos/operation/overlayng/OverlayLabel.h
+include/geos/operation/overlayng/OverlayLabeller.h
+include/geos/operation/overlayng/OverlayMixedPoints.h
+include/geos/operation/overlayng/OverlayNG.h
+include/geos/operation/overlayng/OverlayNGRobust.h
+include/geos/operation/overlayng/OverlayPoints.h
+include/geos/operation/overlayng/OverlayUtil.h
+include/geos/operation/overlayng/PolygonBuilder.h
+include/geos/operation/overlayng/PrecisionReducer.h
+include/geos/operation/overlayng/PrecisionUtil.h
+include/geos/operation/overlayng/RingClipper.h
+include/geos/operation/overlayng/RobustClipEnvelopeComputer.h
+include/geos/operation/overlayng/UnaryUnionNG.h
include/geos/operation/polygonize/BuildArea.h
include/geos/operation/polygonize/EdgeRing.h
include/geos/operation/polygonize/HoleAssigner.h
@@ -344,8 +359,10 @@ include/geos/operation/union/GeometryLis
include/geos/operation/union/OverlapUnion.h
include/geos/operation/union/PointGeometryUnion.h
include/geos/operation/union/UnaryUnionOp.h
+include/geos/operation/union/UnionStrategy.h
include/geos/operation/valid/ConnectedInteriorTester.h
include/geos/operation/valid/ConsistentAreaTester.h
+include/geos/operation/valid/IndexedNestedShellTester.h
include/geos/operation/valid/IsValidOp.h
include/geos/operation/valid/MakeValid.h
include/geos/operation/valid/QuadtreeNestedRingTester.h
@@ -354,7 +371,6 @@ include/geos/operation/valid/RepeatedPoi
include/geos/operation/valid/SimpleNestedRingTester.h
include/geos/operation/valid/SweeplineNestedRingTester.h
include/geos/operation/valid/TopologyValidationError.h
-include/geos/planargraph.h
include/geos/planargraph/DirectedEdge.h
include/geos/planargraph/DirectedEdgeStar.h
include/geos/planargraph/Edge.h
@@ -364,7 +380,6 @@ include/geos/planargraph/NodeMap.h
include/geos/planargraph/PlanarGraph.h
include/geos/planargraph/Subgraph.h
include/geos/planargraph/algorithm/ConnectedSubgraphFinder.h
-include/geos/precision.h
include/geos/precision/CommonBits.h
include/geos/precision/CommonBitsOp.h
include/geos/precision/CommonBitsRemover.h
@@ -374,6 +389,9 @@ include/geos/precision/MinimumClearance.
include/geos/precision/PrecisionReducerCoordinateOperation.h
include/geos/precision/SimpleGeometryPrecisionReducer.h
include/geos/profiler.h
+include/geos/shape/fractal/HilbertCode.h
+include/geos/shape/fractal/HilbertEncoder.h
+include/geos/shape/fractal/MortonCode.h
include/geos/simplify/DouglasPeuckerLineSimplifier.h
include/geos/simplify/DouglasPeuckerSimplifier.h
include/geos/simplify/LineSegmentIndex.h
@@ -382,7 +400,6 @@ include/geos/simplify/TaggedLineString.h
include/geos/simplify/TaggedLineStringSimplifier.h
include/geos/simplify/TaggedLinesSimplifier.h
include/geos/simplify/TopologyPreservingSimplifier.h
-include/geos/spatialIndex.h
include/geos/triangulate/DelaunayTriangulationBuilder.h
include/geos/triangulate/IncrementalDelaunayTriangulator.h
include/geos/triangulate/VoronoiDiagramBuilder.h
@@ -390,6 +407,7 @@ include/geos/triangulate/quadedge/LastFo
include/geos/triangulate/quadedge/LocateFailureException.h
include/geos/triangulate/quadedge/QuadEdge.h
include/geos/triangulate/quadedge/QuadEdgeLocator.h
+include/geos/triangulate/quadedge/QuadEdgeQuartet.h
include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
include/geos/triangulate/quadedge/TrianglePredicate.h
include/geos/triangulate/quadedge/TriangleVisitor.h
@@ -413,3 +431,4 @@ include/geos/version.h
include/geos_c.h
lib/libgeos.la
lib/libgeos_c.la
+lib/pkgconfig/geos.pc
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20201214/7106ebe8/attachment.sig>
