[geos-devel] [GEOS] #732: BufferOp(0.0) makes the attached polygon "miss"!
geos-trac at osgeo.org
Wed Dec 30 15:12:56 PST 2020
Reporter: jiangdaidai | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.9.1
Component: Default | Version: 3.4.2
Severity: Significant | Resolution: fixed
Keywords: BufferOp |
Changes (by Paul Ramsey <pramsey@…>):
* status: reopened => closed
* resolution: => fixed
Comment:
In [changeset:"efe09d6e53ad5e6a7a43747af24f28c6876c6c72/git" efe09d6/git]:
#!CommitTicketReference repository="git"
revision="efe09d6e53ad5e6a7a43747af24f28c6876c6c72"
Port https://github.com/locationtech/jts/pull/655, Fix buffer to use
largest enclosed area for invalid rings
Closes #732
Ticket URL: <https://trac.osgeo.org/geos/ticket/732#comment:10>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
