[geos-devel] [GEOS] #1014: geos-config for Windows?
geos-trac at osgeo.org
Thu Feb 13 19:41:53 PST 2020
Reporter: Mike Taves | Owner: geos-devel@…
Type: enhancement | Status: new
Priority: major | Milestone: 3.9.0
Component: Build/Install (cmake) | Version: master
Severity: Unassigned | Keywords:
Is there any appetite for a `geos-config` for Windows? I've mocked
together a `geos-config.bat` file that mimics the Unix shell-based
version.
Note that a MSVC CMake build will generate a `geos-config` file. A
proposed solution would write a `geos-config.bat` file instead.
One consideration is that some extra flags many be needed for Windows
back-slash shenanigans, for instance `python setup.py build_ext
-IC:\\deps\\geos\\include ...` is needed, therefore perhaps add a
`--escape-backslash` flag.
I can prepare a PR. Any thoughts before I get carried away?
Ticket URL: <https://trac.osgeo.org/geos/ticket/1014>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
