[geos-devel] [GEOS] #1015: Update geos-config tool for consistency
geos-trac at osgeo.org
Mon Feb 17 14:42:03 PST 2020
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: minor | Milestone: 3.9.0
Component: Build/Install (cmake) | Version: master
Severity: Unassigned | Keywords:
Details repeated from https://git.osgeo.org/gitea/geos/geos/pulls/99
**Specify bash, and use printf to escape paths (if needed)**
This allows installation with CMake to other directories, such as `/opt/my
prefix`, since `geos-config --prefix` would return `/opt/my\ prefix`. Also
`printf` is a bash-only feature.
**Restore bash variables, e.g. `${prefix}`, and use CMake's `@ONLY` option
Restore to prior syntax in b15fd1171823d16195bee17f2c7b44778603258d using
`${prefix}` rather than substituting `@CMAKE_INSTALL_PREFIX@`. Re-use
variables throughout script for convenience.
Note that the current autotools setup does not fully install to prefixes
that need escaping, but the CMake setup can.
**Consistent indents and style between .in and .cmake versions**
Use 2-space indents, re-order case statements to same order as usage. The
Autotools and CMake versions are nearly the same, with the exception of
Autotool's `libdir`, which perhaps could be something other than
`$prefix/lib`?
**Remove `exec_prefix`, which has never been used**
Checking the history of this file, it does not seem to be used.
**Disable configure and install for MSVC builds**
The script requires bash, which is not used for MSVC. Scheme to install a
MSVC version of `geos-config.bat` is drafted at [trac#1014](#1014).
Ticket URL: <https://trac.osgeo.org/geos/ticket/1015>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
