[geos-devel] [GEOS] #1013: MultiLineString::reverse should not change component order
GEOS geos-trac at osgeo.org
Thu Jan 30 07:44:18 PST 2020
 Reporter:  dbaston     |      Owner:  geos-devel@…
     Type:  defect      |     Status:  new
 Priority:  major       |  Milestone:  3.7.3
Component:  Default     |    Version:  master
 Severity:  Unassigned  |   Keywords:
 This behavior is inconsistent with other geometry types. Recently fixed in
 JTS.
 Recommend backporting to 3.7.x, where GEOSReverse was added to C API.
 PR at https://github.com/libgeos/geos/pull/271
Ticket URL: <https://trac.osgeo.org/geos/ticket/1013>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
