[geos-devel] [GEOS] #1035: VoronoiLines hangs indefinitely on multipoint
geos-trac at osgeo.org
Tue Jul 21 05:51:37 PDT 2020
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.9.0
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Description changed by robe:
Old description:
> I tested on 3.8.0 (still have to test on 3.8.1) but definitely an issue
> on GEOS head.
> SELECT ST_VoronoiLines('MULTIPOINT(-10 40,5 40,20 40,35 40,50 40,-10 55,5
> 55,20 55,35 55,50 55,-10 70,5 70,20 70,35 70,50 70)'::geometry, 20.1,
> 'POINT(-11.1111111 40)'::geometry)
> See related PostGIS ticket
> https://trac.osgeo.org/postgis/ticket/4726
> Raul's trace
> #0 0x00007fc3eacf126c in geos::triangulate::quadedge::Vertex::isCCW
> (this=<optimized out>, b=..., c=...) at
> ../../../include/geos/triangulate/quadedge/Vertex.h:226
> #1 geos::triangulate::quadedge::Vertex::rightOf (this=0x55bba48b9720,
> e=...) at Vertex.cpp:83
> #2 0x00007fc3eace807c in
> geos::triangulate::IncrementalDelaunayTriangulator::insertSite
> (this=<optimized out>, v=...) at IncrementalDelaunayTriangulator.cpp:90
> #3 0x00007fc3eace7e4b in
> geos::triangulate::IncrementalDelaunayTriangulator::insertSites
> (this=0x7ffe3cf96408, vertices=...) at
> IncrementalDelaunayTriangulator.cpp:40
> #4 0x00007fc3eace9f5d in
> geos::triangulate::VoronoiDiagramBuilder::create (this=0x7ffe3cf964b8) at
> VoronoiDiagramBuilder.cpp:93
> #5 0x00007fc3eacea45b in
> geos::triangulate::VoronoiDiagramBuilder::getDiagramEdges
> (this=0x7ffe3cf964b8, geomFact=...) at VoronoiDiagramBuilder.cpp:122
> #6 0x00007fc3eba9c83e in GEOSVoronoiDiagram_r::$_188::operator()
> (this=<optimized out>) at geos_ts_c.cpp:3261
> #7 execute<GEOSVoronoiDiagram_r::$_188,
> (decltype(nullptr))0>(GEOSContextHandle_HS*,
> GEOSVoronoiDiagram_r::$_188&&) (extHandle=0x55bba48b88b0, f=...) at
> geos_ts_c.cpp:379
> #8 GEOSVoronoiDiagram_r (extHandle=0x55bba48b88b0, g1=0x55bba48b6840,
> env=0x55bba48e6f40, tolerance=20.100000000000001, onlyEdges=1) at
> geos_ts_c.cpp:3253
> #9 0x00007fc3ebc02ecb in lwgeom_voronoi_diagram (g=<optimized out>,
> env=0x7ffe3cf965c0, tolerance=20.100000000000001,
> output_edges=-1534355264) at lwgeom_geos.c:1926
> #10 0x00007fc3ebb3267e in ST_Voronoi (fcinfo=0x55bba48fbb20) at
> lwgeom_geos.c:3465
> #11 0x000055bba3c126e1 in ExecInterpExpr (state=<optimized out>,
> econtext=<optimized out>, isnull=0x7ffe3cf9675f) at execExprInterp.c:625
> #12 0x000055bba3c45874 in ExecEvalExprSwitchContext
> (state=0x55bba48fba48, econtext=0x55bba48fb770, isNull=0x7ffe3cf9675f) at
> ../../../src/include/executor/executor.h:307
> (gdb) c
> Continuing.
> ^C
> Program received signal SIGINT, Interrupt.
> geos::triangulate::quadedge::Vertex::isCCW (this=<optimized out>, b=...,
> c=...) at ../../../include/geos/triangulate/quadedge/Vertex.h:227
> 227 > (b.p.y - p.y) * (c.p.x - p.x);
> (gdb) bt
> #0 geos::triangulate::quadedge::Vertex::isCCW (this=<optimized out>,
> b=..., c=...) at ../../../include/geos/triangulate/quadedge/Vertex.h:227
> #1 geos::triangulate::quadedge::Vertex::rightOf (this=0x55bba48b9ee0,
> geos_ts_c.cpp:379
> geos_ts_c.cpp:3253
> lwgeom_geos.c:3465
New description:
I tested on 3.8.0 and works fine there (still have to test on 3.8.1) but
definitely an issue on GEOS head.
Raul's trace
#4 0x00007fc3eace9f5d in geos::triangulate::VoronoiDiagramBuilder::create
(this=0x7ffe3cf964b8) at VoronoiDiagramBuilder.cpp:93
geos_ts_c.cpp:379
geos_ts_c.cpp:3253
lwgeom_geos.c:3465
#12 0x000055bba3c45874 in ExecEvalExprSwitchContext (state=0x55bba48fba48,
(gdb) c
Continuing.
^C
(gdb) bt
geos_ts_c.cpp:379
geos_ts_c.cpp:3253
lwgeom_geos.c:3465
Ticket URL: <https://trac.osgeo.org/geos/ticket/1035#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
