[geos-devel] Request for Eyeballs
Paul Ramsey pramsey at cleverelephant.ca
Mon Jul 27 12:46:55 PDT 2020
> On Jul 24, 2020, at 6:35 AM, Sandro Santilli <strk at kbt.io> wrote:
> Paul, FYI: I've pushed some fixes to that branch. Keep this in mind
> before you change your local copy too much. It's just some override
> keywords and a fix to autotools scripts at time of writing.
Pushed to github or osgeo? I'm working on github. I don't see any changes.
> The code, in its current form, passes `make check` (not sure how much
> of the new code `make check` actually tests, but I saw some unit test).
Autotools make check might be missing some of the new XML files, as they have to be manually added still. All unit tests should run in both builds.
P
> --strk;
> On Fri, Jul 24, 2020 at 12:07:44PM +0200, Sandro Santilli wrote:
>> On Thu, Jul 23, 2020 at 08:22:44PM -0700, Paul Ramsey wrote:
>>> I'm trying to clean up memory use in the new overlayng code, on the overlay-sr branch, and have come to an impasse.
>>> The valgrind report is here: https://gist.github.com/pramsey/d4be398473ea49ff4e241f5e7d4b855b
>> That report contains multiple leaks, which are reported from smaller
>> to bigger, so I'd start at the end of it:
>> ==6519== 59,784,992 (40,104 direct, 59,744,888 indirect) bytes in 1,671 blocks are definitely lost in loss record 8,846 of 8,847
>> ==6519==    at 0x4C29203: operator new(unsigned long) (vg_replace_malloc.c:334)
>> ==6519==    by 0x528EBAA: geos::noding::NodedSegmentString::getNodedSubstrings(std::vector<geos::noding::SegmentString*, std::allocator<geos::noding::SegmentString*> > const&) (NodedSegmentString.cpp:148)
>> The ownership of those SegmentStrings is not documented in
>> NodedSegmentString.h, which would help. My impression is that
>> those segment strings should be shared pointers, to overcome this
>> long standing issue (it was a problem before snaprounding as well).
>> I think the caller should take ownership of those objects.
>> In this case, the caller is ValidatingNoder, which is storing
>> those into its 'nodedSS' member, which is an heap-allocated
>> vector. That vector is returned by
>> ValidatingNoder::getNodedSubstrings() which is also undocumented
>> but is probably expected to pass ownership back to its own caller.
>> I suggest you destroy the vector and its contents IFF
>> getNodedSubstring is never called, which may be the case here.
>> Or (bigger change) use shared pointers.
>> PS: I like the DEVELOPER-NOTES.md file
>> --strk;
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geos-devel
