[geos-devel] [GEOS] #1037: GeosMakeValid returning NULL -- regular GEOS Master 3.9
GEOS geos-trac at osgeo.org
Fri Jul 31 16:01:02 PDT 2020
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  blocker     |   Milestone:  3.9.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Okay cunit is passing again and as mentioned on IRC, switched debbie to
 retest PostGIS master after CI of GEOS Master so we catch these issues
 early.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1037#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
