[geos-devel] millions of lines intersection against single polygon
Andrew Bell andrew.bell.ia at gmail.com
Thu Jun 25 10:03:04 PDT 2020
On Thu, Jun 25, 2020 at 2:55 AM Nyall Dawson <nyall.dawson at gmail.com> wrote:
> Hi list!
> I've a situation where I've got ~millions of lines (each consisting of
> a single segment only) which I need to intersect against a complex
> polygon.
> Trying the naive way of multiple calls to GEOSIntersection_r gives
> predictably horrendous performance. Is there a better way I can
> approach this situation using the GEOS c api?
There's an algorithm in PDAL that does this for point-in-polygon, but all
the guts are there to do segment intersections. You're welcome to take it
and modify to your liking:
https://github.com/PDAL/PDAL/tree/master/filters/private/pnp
How much better it would from a more brute-force approach depends a lot on
the data.
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20200625/76ed0d8a/attachment.html>
