[geos-devel] OverlayNG Port
Paul Ramsey
pramsey at cleverelephant.ca
Thu May 21 11:45:39 PDT 2020
Hey all,
I've started on porting OverlayNG from JTS. I'm not very good at this,
so I anticipate it will take quite some time :)
If you would like to help, the working branch is here,
https://github.com/libgeos/geos/tree/overlay-sr
And I have set up a sheet to track work here,
https://docs.google.com/spreadsheets/d/15Jk5cNuYdxPPA9fXIxCreRJNlkQZjc2KdYaX-odW8So/edit#gid=0
And the global JTS diff against master is here,
https://github.com/locationtech/jts/compare/master...dr-jts:overlay-sr
May the force be with us,
P
