[geos-devel] OverlayNG as Default
Paul Ramsey
pramsey at cleverelephant.ca
Tue Nov 3 14:45:17 PST 2020
The switch has been flipped.
If you build GEOS without any options, you will get the OverlayNG engine
backing the standard geometry functions.
geom->union()
geom->intersection()
geom->symdifference()
geom->difference()
geom->unaryunion()
The unit and XML tests that differed from the old engine have been updated
to match the new NG outputs. That means if you use the --disable-overlayng
option in autotools or the DISABLE_OVERLAYNG option in cmake, not all tests
will pass anymore. NG is the new normal.
P.
On Fri, Oct 30, 2020 at 1:10 PM Regina Obe <lr at pcorp.us> wrote:
> +1 for flipping the switch.
> I don’t know what “light your hair on fair” means J
> *From:* geos-devel [mailto:geos-devel-bounces at lists.osgeo.org] *On Behalf
> Of *Paul Ramsey
> *Sent:* Friday, October 30, 2020 3:47 PM
> *To:* GEOS Development List <geos-devel at lists.osgeo.org>
> *Subject:* [geos-devel] OverlayNG as Default
> OK, it's been a while, and I'd like to flip over GEOS master to use
> OverlayNG as the engine behind
> Geometry.intersection()
> Geometry.difference()
> Geometry.union()
> Geometry.symdifference()
> Geometry.unaryunion()
> That will entail changing the expected outputs for a few of the regression
> tests, as detailed here.
> https://docs.google.com/document/d/1TDm2aR4a7O41-soS-25Xog1EdQcjmvKCnKltxjbxOC0/edit#heading=h.ojs23hjdmk7a
> Once that is done, regressions in PostGIS and other downstream projects
> can be #ifdef'ed around GEOS version. As seen in the document above, there
> actually aren't than many cases that need special handling in PostGIS, and
> hopefully not in other downstream projects.
> If you have any concerns, please light your hair on fair in the next
> couple days.
> P.
> geos-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20201103/64006a61/attachment.html>
