[geos-devel] [GEOS] #1047: GEOS Panics on GeometryCollection with 1 MultiPolygon object
GEOS geos-trac at osgeo.org
Fri Nov 6 11:31:19 PST 2020
 Reporter:  otan        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  3.8.0
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Changes (by Sandro Santilli <strk@…>):
 * status:  reopened => closed
 * resolution:   => fixed
Comment:
 In [changeset:"dfceb3487c2edcba75dac8a47c0153c6ee585305/git" dfceb34/git]:
 #!CommitTicketReference repository="git"
 revision="dfceb3487c2edcba75dac8a47c0153c6ee585305"
 Fix segfault in SimplePointInAreaLocator
 Backport of patch by Oliver Tan
 Closes #1047 in 3.8 branch (3.8.2dev)
 References https://github.com/cockroachdb/cockroach/issues/53254
Ticket URL: <https://trac.osgeo.org/geos/ticket/1047#comment:6>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
