[geos-devel] [GEOS] #1024: ttmath is platform dependent
GEOS geos-trac at osgeo.org
Fri Nov 6 16:07:33 PST 2020
 Reporter:  pramsey     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:  3.8.2
Component:  Default     |     Version:  3.8.0
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Replaced with DD in master, leaving as is on 3.8 until someone has a
 problem.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1024#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
