[geos-devel] [GEOS] #859: Voronoi issue
geos-trac at osgeo.org
Fri Nov 6 16:50:57 PST 2020
#859: Voronoi issue
Reporter: jjgreen | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.6.4
Component: Default | Version: 3.5.1
Severity: Unassigned | Resolution:
Keywords: |
Comment (by mdavis):
I did run this against master as a C++ unit test (but didn't commit it
because data is so large). I can commit it if that seems like a good idea
(there is a unit test which is a subset of this data though).
Or, have been thinking about adding ability to run Delaunay and Voronoi as
XML tests (should be fairly easy).
Ticket URL: <https://trac.osgeo.org/geos/ticket/859#comment:11>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
