[geos-devel] [GEOS] #1068: Fix CMake Windows install: keep geos-config.cmake
geos-trac at osgeo.org
Mon Nov 16 01:59:02 PST 2020
Reporter: Mike Taves | Owner: geos-devel@â¦
Type: defect | Status: new
Priority: blocker | Milestone:
Component: Build/Install (cmake) | Version: master
Severity: Unassigned | Keywords:
For a correct Windows install, `geos-config.cmake` needs to be installed.
This file is not related to the non-Windows `geos-config` utility.
This is a partial rollback of daf24a4d4025b9068a6f0354da981270182fbdb4
See https://github.com/libgeos/geos/pull/347
Ticket URL: <https://trac.osgeo.org/geos/ticket/1068>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
