[geos-devel] [GEOS] #1071: Setting lower precision of polygon always collapses polygon
geos-trac at osgeo.org
Mon Nov 23 16:29:09 PST 2020
Reporter: Brendan Ward | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: 3.5.1
Severity: Unassigned | Resolution:
Keywords: |
Comment (by mdavis):
The goal of GEOS operations is to always produce valid output. A polygon
with zero extent is invalid, so the closest valid result is `POLYGON
EMPTY`. Another way to put this is that if a polygon collapses completely
due to rounding, it disappears rather than becoming a point.
The collapsed LinearRing result is in fact also invalid. So probably the
current result is out of spec, and should be changed to become
`LINEARRING EMPTY`. (In fact this should be the behaviour of the latest
GEOS version incorporating OverlayNG).
Ticket URL: <https://trac.osgeo.org/geos/ticket/1071#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
