[geos-devel] [GEOS] #1064: Topology preserve simplify: unexpected behavior on similar polygons
GEOS geos-trac at osgeo.org
Fri Nov 27 12:00:24 PST 2020
 Reporter:  uclaros     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  minor       |   Milestone:  3.9.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by mdavis):
 Replying to [comment:5 uclaros]:
 > take the current resulting polygon, use its 0, 1, n-1 and n (same as 0)
 vertices to decide if 0 and n vertices should also be removed.
 Good idea.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1064#comment:6>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
