[geos-devel] MSVC Unit Failure
Paul Ramsey
pramsey at cleverelephant.ca
Fri Nov 27 20:59:10 PST 2020
The actual build logs you can see here
https://dev.azure.com/libgeos/geos/_build/results?buildId=772&view=logs&jobId=305851a9-a7bb-55db-0042-7e2b6f48aa1c&j=2bd7b19d-6351-5e7f-8417-63f327ab45bc
To add to the wierdness, MSVC 2017 C++ 14 works. MSVC 2017 C++ 17 does not.
Platforms!
P
> On Nov 27, 2020, at 10:53 AM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> Any of our MSVC list members want to take a look at this unit test failure? After cleaning up build errors and warnings it is what's left in our CI breakages.
> The following tests FAILED:
> Errors while running CTest
> 198 - unit-simplify-TopologyPreservingSimplifier (Failed)
> P.
