[geos-devel] [GEOS] #1078: [C API] GEOSCoordSeq_setOrdinate no longer returns error code
    geos-trac at osgeo.org
    Sat Nov 28 12:29:14 PST 2020
 Reporter:  jorisvandenbossche  |       Owner:  geos-devel@…
     Type:  defect              |      Status:  closed
 Priority:  major               |   Milestone:  3.9.0
Component:  Default             |     Version:  master
 Severity:  Unassigned          |  Resolution:  fixed
 Keywords:                      |
Changes (by Joris Van den Bossche <jorisvandenbossche@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"48d02f65db373bf915ad225a9385c5713077c39e/git" 48d02f6/git]:
 #!CommitTicketReference repository="git"
 revision="48d02f65db373bf915ad225a9385c5713077c39e"
 Fix return error code of GEOSCoordSeq_setOrdinate (closes #1078)
Ticket URL: <https://trac.osgeo.org/geos/ticket/1078#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
