[geos-devel] [GEOS] #1051: overlayng::EdgeMerger::merge(): Assertion `baseEdge->size() == edge->size()' failed.
GEOS geos-trac at osgeo.org
Mon Oct 5 04:34:25 PDT 2020
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  blocker     |   Milestone:  3.9.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Comment (by strk):
 For the record: SnappingNoderTest can be run in JTS as such:
 java -cp \
 ./modules/core/target/jts-core-1.18.0-SNAPSHOT.jar:./modules/core/target
 /jts-core-1.18.0-SNAPSHOT-
 tests.jar:/home/strk/.m2/repository/junit/junit/4.12/junit-4.12.jar \
 org.locationtech.jts.noding.snap.SnappingNoderTest
 Will still need a way to avoid the long literal
Ticket URL: <https://trac.osgeo.org/geos/ticket/1051#comment:18>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
