[geos-devel] [GEOS] #1051: overlayng::EdgeMerger::merge(): Assertion `baseEdge->size() == edge->size()' failed.
geos-trac at osgeo.org
Mon Oct 5 09:29:52 PDT 2020
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: closed
Priority: blocker | Milestone: 3.9.0
Component: Default | Version: master
Severity: Unassigned | Resolution: fixed
Keywords: |
Comment (by mdavis):
This is what the
[https://github.com/locationtech/jts/blob/master/doc/JTSOp.md jtsop
utility] is for. You can put WKT or WKB in files, and run any function
that is provided in the TestBuilder (which is many), or else run your own
(by add a class file containing static methods).
So if you have the following files:
snapping-test-a.wkt:
LINESTRING (100 200, 200 100.1, 300 100)
snapping-test-b.wkt:
the SnappingNoder can be run using:
<JTS_HOME>/bin/jtsop.sh -a snapping-test-a.wkt -b snapping-test-b.wkt -f
wkt Noding.snappingNoder 1
(Note that the Noding.snappingNoder function actually allows a null second
input, but at the moment the jtsop command doesn't recognize this).
Ticket URL: <https://trac.osgeo.org/geos/ticket/1051#comment:21>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
