[geos-devel] [GEOS] #1054: BuildArea behavior changed intentional? and when did it happen
GEOS geos-trac at osgeo.org
Mon Oct 5 13:54:29 PDT 2020
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  3.6.2
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Description changed by robe:
Old description:
> strk suggested I put the ticket
> https://trac.osgeo.org/postgis/ticket/4763
> Here as PostGIS uses GEOS directly for ST_BuildArea.
> The issue is:
> SELECT ST_BuildArea('MULTIPOLYGON(((186.464466094067
> 193.535533905933,187.222148834902 194.157348061513,188.086582838175
> 194.619397662556,189.024548389919 194.903926402016,190
> 195,190.975451610081 194.903926402016,191.913417161825
> 194.619397662556,192.777851165098 194.157348061513,193.535533905933
> 193.535533905933,194.157348061513 192.777851165098,194.619397662556
> 191.913417161825,194.903926402016 190.975451610081,195
> 190,194.903926402016 189.024548389919,194.619397662556
> 188.086582838175,194.157348061513 187.222148834902,193.535533905933
> 186.464466094067,13.5355339059327 6.46446609406726,12.777851165098
> 5.84265193848727,11.9134171618254 5.38060233744356,10.9754516100806
> 5.09607359798385,10 5,9.02454838991936 5.09607359798385,8.08658283817455
> 5.38060233744357,7.22214883490199 5.84265193848727,6.46446609406726
> 6.46446609406726,5.84265193848728 7.22214883490199,5.38060233744357
> 8.08658283817455,5.09607359798385 9.02454838991935,5
> 9.99999999999999,5.09607359798385 10.9754516100806,5.38060233744356
> 11.9134171618254,5.84265193848727 12.777851165098,6.46446609406726
> 13.5355339059327,186.464466094067 193.535533905933)),((150
> 90,149.039264020162 80.2454838991936,146.193976625564
> 70.8658283817455,141.573480615127 62.2214883490199,135.355339059327
> 54.6446609406727,127.77851165098 48.4265193848728,119.134171618255
> 43.8060233744357,109.754516100806 40.9607359798385,100
> 40,90.2454838991937 40.9607359798385,80.8658283817456
> 43.8060233744356,72.22148834902 48.4265193848727,64.6446609406727
> 54.6446609406725,58.4265193848728 62.2214883490198,53.8060233744357
> 70.8658283817454,50.9607359798385 80.2454838991934,50
> 89.9999999999998,50.9607359798384 99.7545161008062,53.8060233744356
> 109.134171618254,58.4265193848726 117.77851165098,64.6446609406725
> 125.355339059327,72.2214883490197 131.573480615127,80.8658283817453
> 136.193976625564,90.2454838991934 139.039264020161,99.9999999999998
> 140,109.754516100806 139.039264020162,119.134171618254
> 136.193976625564,127.77851165098 131.573480615127,135.355339059327
> 125.355339059327,141.573480615127 117.77851165098,146.193976625564
> 109.134171618255,149.039264020162 99.7545161008065,150 90)))'::geometry);
> Used to look like:
> [[Image(before_gaping_hole.png)]]
> But now looks like
> [[Image(after_gaping_hole_no_more.png)]]
> SELECT ST_BuildArea('MULTIPOLYGON(((91 50,79 22,51 10,23 22,11 50,23
> 78,51 90,79 78,91 50)),((91 100,79 72,51 60,23 72,11 100,23 128,51 140,79
> 128,91 100)),((91 150,79 122,51 110,23 122,11 150,23 178,51 190,79 178,91
> 150)),((141 50,129 22,101 10,73 22,61 50,73 78,101 90,129 78,141
> 50)),((141 100,129 72,101 60,73 72,61 100,73 128,101 140,129 128,141
> 100)),((141 150,129 122,101 110,73 122,61 150,73 178,101 190,129 178,141
> 150)))'::geometry);
> Used to Look like:
> [[Image[before_beautiful_beehive.png]]
> After
> [[Image[after_boring_beehive.png]]
> I think this has been (broken for me) and it's unclear if this was an
> intentional change or not. I personally prefer the old behavior, but as I
> review more I can understand how someone may have decided the new
> behavior was more predictable and thus better.
> So it's been like this I would say probably since 3.6 (maybe even as
> early as 3.5). One pattern I see with the failures is they are all
> invalid polygons. So perhaps it's doing an UnaryUnion or something before
> feeding to ST_BuildArea.
New description:
 The issue is:
 43.8060233744357,109.754516100806 40.9607359798385,100 40,90.2454838991937
 40.9607359798385,80.8658283817456 43.8060233744356,72.22148834902
 48.4265193848727,64.6446609406727 54.6446609406725,58.4265193848728
 62.2214883490198,53.8060233744357 70.8658283817454,50.9607359798385
 80.2454838991934,50 89.9999999999998,50.9607359798384
 99.7545161008062,53.8060233744356 109.134171618254,58.4265193848726
 117.77851165098,64.6446609406725 125.355339059327,72.2214883490197
 131.573480615127,80.8658283817453 136.193976625564,90.2454838991934
 139.039264020161,99.9999999999998 140,109.754516100806
 139.039264020162,119.134171618254 136.193976625564,127.77851165098
 131.573480615127,135.355339059327 125.355339059327,141.573480615127
 117.77851165098,146.193976625564 109.134171618255,149.039264020162
 Used to look like:
 But now looks like
 SELECT ST_BuildArea('MULTIPOLYGON(((91 50,79 22,51 10,23 22,11 50,23 78,51
 90,79 78,91 50)),((91 100,79 72,51 60,23 72,11 100,23 128,51 140,79 128,91
 150)))'::geometry);
 Used to Look like:
 [[Image(before_beautiful_beehive.png)]
 After
 [[Image(after_boring_beehive.png)]
 review more I can understand how someone may have decided the new behavior
 So it's been like this I would say probably since 3.6 (maybe even as early
 as 3.5). One pattern I see with the failures is they are all invalid
 polygons. So perhaps it's doing an UnaryUnion or something before feeding
 to ST_BuildArea.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1054#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
