[geos-devel] [GEOS] #1054: BuildArea behavior changed intentional? and when did it happen
geos-trac at osgeo.org
Tue Oct 6 16:18:20 PDT 2020
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone:
Component: Default | Version: 3.6.2
Severity: Unassigned | Resolution: wontfix
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => wontfix
Comment:
okay guess by design then -- I've moved examples in PostGIS to
ST_MakeValid.
as noted in https://trac.osgeo.org/postgis/ticket/4763
Ticket URL: <https://trac.osgeo.org/geos/ticket/1054#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
