[geos-devel] [GEOS] #1012: Thread Sanitizer warns of data race in geos::util::Interrupt::cancel()
geos-trac at osgeo.org
Sat Oct 10 11:48:38 PDT 2020
Reporter: macdrevx | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by macdrevx):
I've spent some time considering what would be gained by making
`requested` atomic. While it would avoid the data race on that particular
memory, it would not result in a thread-safe system overall.
Consider this example: there are long-running operations on 2 threads. A
3rd thread requests an interrupt. The result could be either:
A. 1 thread is interrupted (passes the check at Interrupt.cpp:66 and
executes line 67 to lock out the other thread), or
B. Both threads are interrupted. (Both threads pass the check at
Interrupt.cpp:66 before either one executes line 67).
Which scenario occurs (and within scenario A, which thread is interrupted)
depends on the timing.
A better solution would provide an interface that allows the consumer to
be specific about their intent. My current thought is that for the thread
safe CAPI we could design a new interface that would allow requesting an
interrupt only on a specific context. Ideally, any such interface would
avoid requiring the CAPI consumer to implement synchronization mechanisms
around the context. Optionally, we could maintain the existing
`GEOS_interruptRequest` interface to allow requesting interruption on
'''all''' contexts.
I have some implementation ideas, but I'll wait to share them until after
getting some feedback about whether this general direction is desirable.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1012#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
