[geos-devel] [GEOS] #1051: overlayng::EdgeMerger::merge(): Assertion `baseEdge->size() == edge->size()' failed.
GEOS geos-trac at osgeo.org
Mon Oct 12 07:19:13 PDT 2020
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  reopened
 Priority:  blocker     |   Milestone:  3.9.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"8d203e348716efed8da34c18b40309259a90024e/git" 8d203e3/git]:
 #!CommitTicketReference repository="git"
 revision="8d203e348716efed8da34c18b40309259a90024e"
 Add test for https://trac.osgeo.org/geos/ticket/1051
 References #1051
Ticket URL: <https://trac.osgeo.org/geos/ticket/1051#comment:34>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
