[geos-devel] Checking GEOS master (state 8 October)
Roger Bivand Roger.Bivand at nhh.no
Tue Oct 13 11:23:49 PDT 2020
On Tue, 13 Oct 2020, Paul Ramsey wrote:
>> On Oct 13, 2020, at 11:08 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>> I've been checking the possible fallout from Overlay_NG (assuming that
>> building from master on 8 October uses the new code) in some R
>> packages, in particular sf and rgeos. I see messages such as:
>> CBR: result (after common-bits addition) is INVALID: Self-intersection
>> at or near point 368576.69999999995 864696 (368576.69999999995343
>> 864696)
> That looks like the old overlay handler. Have you turned NG on in your
> build?
Thanks for the quick response. First, is "master" the correct branch
(gitea)? If yes, what is the incantation - I couldn't find any reference
to NG in the code or configure.ac? I'd assumed from earlier discussion
here that NG was on by default on "master".
Roger
> P
>> followed by the text representation of the object dumped to console.
>> The message and the dumped object are not passed through error or
>> warning handlers passed in through initGEOS_r(), and so are hard to
>> trap and handle. Is this a temporary feature which will be normalised
>> for 3.9.0?
>> So far I don't think that there are obvious failures in R packages
>> related to the new code (again assuming that a straight build of master
>> of 8 November exercises Overlay_NG), but the unexpected output was
>> surprising.
>> Best wishes,
>> Roger
>> Roger Bivand
>> Department of Economics, Norwegian School of Economics,
>> Helleveien 30, N-5045 Bergen, Norway.
>> voice: +47 55 95 93 55; e-mail: Roger.Bivand at nhh.no
>> https://orcid.org/0000-0003-2392-6140
>> https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geos-devel
Roger Bivand
