[geos-devel] [GEOS] #1005: Writing POINT EMPTY in WKB
geos-trac at osgeo.org
Thu Oct 29 18:01:14 PDT 2020
Reporter: Mike Taves | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone:
Component: Default | Version: master
Severity: Annoyance | Resolution: fixed
Keywords: |
Comment (by pramsey):
In general the WKT parser did not parse in "GEOMETRY Z EMPTY" forms and
notice there was a Z there. Point was fiddly to fix, and that still left
other types, so I figured I'd fix them all... turns out the core model of
GEOS/JTS can't even represent a "GEOMETRYCOLLECTION Z EMPTY" of any type.
There's nowhere for the dimensionality to live!
Also! The question of what to instantiate for a "POINT EMPTY",
dimensionally speaking. The default in the code was a 3D empty. That
seemed wrong to me, so I've moved it down to a 2D empty. That should also
cause other things to harmonize. There was also a bug hiding, in the
clone() method, that incorrectly cloned 2D POINT EMPTY.
Anyways, just waiting for a CI build before merging, but suffice to say
this isn't a *comprehensive* fix, since that requires some larger
restructuring to even be able to represent some of these concepts that are
expressible in WKT and WKB.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1005#comment:9>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
