[geos-devel] [GEOS] #1047: GEOS Panics on GeometryCollection with 1 MultiPolygon object
geos-trac at osgeo.org
Wed Sep 2 12:37:24 PDT 2020
Reporter: otan | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: 3.8.0
Severity: Unassigned | Resolution:
Keywords: |
Comment (by mdavis):
As background, the reason general GCs aren't supported for predicstes in
general is because of the difficulty of computing some of the more
specific predicates over inputs containing overlapping polygons.
The `intersects` predicate could be computed correctly, in theory. But
this will require a different code path to the other predicates.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1047#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
