[geos-devel] [GEOS] #980: GEOSBuffer emits invalid buffering a collection
GEOS geos-trac at osgeo.org
Mon Sep 14 10:53:58 PDT 2020
 Reporter:  komzpa      |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  3.7.0
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by mdavis):
 The data is in #979 and #978.
 Yes, there is no contract about buffer(0) fixing invalid geometry
 (although it actually does for many cases).  We should focus on ensuring
 that OverlayNG works with this data (and it is included as part of the
 OverlayNG robustness unit tests [https://github.com/dr-jts/jts/blob
 /overlayng-tests/modules/tests/src/test/resources/testxml/robust/overlay
 /TestOverlay-geos-979.xml here]
Ticket URL: <https://trac.osgeo.org/geos/ticket/980#comment:5>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
