[geos-devel] [GEOS] #1051: overlayng::EdgeMerger::merge(): Assertion `baseEdge->size() == edge->size()' failed.
GEOS geos-trac at osgeo.org
Mon Sep 28 08:10:01 PDT 2020
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  3.9.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by mdavis):
 Replying to [comment:3 strk]:
 > I tried {{{   <op name="differencesr" arg1="A" arg2="B"
 arg3="1.79499e-06"> }}} but it returns a POLYGON EMPTY, which doesn't make
 much sense to me (both in JTS and GEOS)
 Yes, because that is using SnapRounding, which is not what needs to be
 tested.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1051#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
