[geos-devel] [GEOS] #1051: overlayng::EdgeMerger::merge(): Assertion `baseEdge->size() == edge->size()' failed.
geos-trac at osgeo.org
Mon Sep 28 12:50:04 PDT 2020
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: closed
Priority: blocker | Milestone: 3.9.0
Component: Default | Version: master
Severity: Unassigned | Resolution: fixed
Keywords: |
Changes (by Sandro Santilli <strk@…>):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"abb96620c275dc898be5795261359e4c0ce3760c/git" abb9662/git]:
#!CommitTicketReference repository="git"
revision="abb96620c275dc898be5795261359e4c0ce3760c"
Throw TopologyException on noding error after snapping
Fixes #1051
NOTE: JTS passes the test without change, so we should really fix
the noding code...
Ticket URL: <https://trac.osgeo.org/geos/ticket/1051#comment:10>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
