[geos-devel] [GEOS] #1051: overlayng::EdgeMerger::merge(): Assertion `baseEdge->size() == edge->size()' failed.
GEOS geos-trac at osgeo.org
Tue Sep 29 09:53:34 PDT 2020
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  blocker     |   Milestone:  3.9.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Comment (by strk):
 Here's what happens to me:
 $ bin/testrunner.sh -geomfunc \
 > org.locationtech.jtstest.function.OverlayNGRobustFunctions \
 > org.locationtech.jts.operation.overlayng.OverlayNGRobust \
 > -files TestOverlayNG-geos-1051.xml
 =====  Test Runner  -  JTS Topology Suite (Version 1.18.0 SNAPSHOT) =====
 Adding Geometry Functions from:
 java.lang.ClassNotFoundException:
         at
 java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:581)
         at
 java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:178)
         at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
         at
 org.locationtech.jtstest.geomop.GeometryFunctionRegistry.add(GeometryFunctionRegistry.java:77)
         at
 org.locationtech.jtstest.testrunner.JTSTestRunnerCmd.readOptions(JTSTestRunnerCmd.java:227)
         at
 org.locationtech.jtstest.testrunner.JTSTestRunnerCmd.main(JTSTestRunnerCmd.java:205)
Ticket URL: <https://trac.osgeo.org/geos/ticket/1051#comment:12>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
