[geos-devel] [GEOS] #1114: CAPI STRtree functions swallow errors
GEOS geos-trac at osgeo.org
Fri Apr 16 09:00:15 PDT 2021
 Reporter:  dbaston     |      Owner:  geos-devel@…
     Type:  defect      |     Status:  new
 Priority:  major       |  Milestone:  3.10.0
Component:  Default     |    Version:  master
 Severity:  Unassigned  |   Keywords:
 GEOSSTRtree_insert, GEOSTRtree_query, and GEOSSTRtree_iterate all return
 void instead of an integer error code. If an exception is thrown in these
 functions it cannot be detected by calling code.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1114>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
