[geos-devel] [GEOS] #1122: BuildArea is slow when there are many holes
geos-trac at osgeo.org
Wed Aug 11 13:56:46 PDT 2021
Reporter: strk | Owner: geos-devel@…
Type: enhancement | Status: new
Priority: major | Milestone: 3.9.2
Component: Default | Version: 3.9.0
Severity: Unassigned | Resolution:
Keywords: |
Comment (by mdavis):
As noted in the code,
[https://git.osgeo.org/gitea/geos/geos/src/branch/main/src/operation/polygonize/BuildArea.cpp#L109
this line] is going to be very slow, since it uses topological `equals`:
if( f2er->equals(hole) )
I am dubious about the correctness of checking only a single point to
decide if the rings are equal (as suggested in the
[https://gitlab.com/geos/libgeos/-/merge_requests/3 GitLab merge request
3].)
This can be improved by using a custom ring equality comparison function.
The rings are equal iff they contain the same points, possibly rotated.
So the function can first compare the envelopes, and then find the lowest
point in each ring, and then walk the rings comparing their points.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1122#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
